2000 Camry 2.2 rough starts
Old Jun 8, 2007 | 11:07 AM
red73mustang's Avatar
Default 2000 Camry 2.2 rough starts
I have a code reader that I can try, but if none show up, is there a "PCV" valve or fuel filter that I can check under the hood to trouble shoot my rough starting problem?
Thanks, Chet
Old Jun 8, 2007 | 10:40 PM
05cam's Avatar
Default RE: 2000 Camry 2.2 rough starts
try just turning the key to the on positon ....all the way but dont start it basically. give it a few seconds and try to start it. if it starts up fine try it a couple of times and see if it helps..my guess is your not letting the fuel pump pressurize up. then agian it could be a fuel filter clogged injectors ect...good luck
Old Jun 9, 2007 | 06:59 AM
pedro's Avatar
If fuel filter you would notice problems with high load first, like acceleration and going up hill, not starting problems. When was the last time you changed plugs, wires etc. You can pull the plugs and see what condition they're in. If you did't get a CEL light I don't think there's much chance of a code.
Old Jun 9, 2007 | 09:40 AM
Thanks for the replys. So far I don't get any cel lights (or idiot lights) on the dash so thats whey I have not put the code reader on it. I too thought of my not waiting long enough for the fuel pump to kick in so I will try waiting a few seconds before starting. I have never changed the plugs or wires and have put 10 k miles on after buying it. Time for a tune up!
Thanks, Chet
ferkkila
Feb 3, 2011 10:07 PM
cdeal28078
Sep 14, 2009 01:52 PM
Camry_Mom
Sep 24, 2008 10:35 PM
audioe420
May 8, 2008 06:51 AM
sstockman99
Apr 30, 2008 07:18 PM
