2003 coolant drain
Old Aug 26, 2022 | 05:30 PM
CamCam22's Avatar
Default 2003 coolant drain
This is my first time changing the coolant on a 2003 camry. I'm just doing a drain and fill. Wanted to double check that this is the right coolant before messing something up:
https://www.autozone.com/antifreeze-...95_0?rrec=true
Old Aug 26, 2022 | 08:52 PM
Good to go.
Old Aug 26, 2022 | 10:36 PM
CamCam22's Avatar
thanks!
Old Aug 27, 2022 | 11:58 AM
One tip when doing the drain and refill is to measure how much coolant drained out and then make sure the same amount goes back in.
Air can get into the large coolant hoses causing less coolant to go in. If having issues of adding this replacement coolant squeeze the large radiator hoses to force out the air.
indiglofish61
Aug 11, 2022 10:31 PM
EZDriver
Dec 30, 2017 04:32 PM
bigblue
Jul 5, 2012 11:44 AM
dfmarc92
Jul 3, 2012 08:52 PM
buffitz
Jul 6, 2008 07:51 AM
