2004 2.4L no start; spark to only cylinder 2
I apologize for the length of this post but I want to share everything in hopes someone might see something I missed. I've got a frustrating problem. My daughter's 2004 2.4L has been running well for years but recently it started having trouble overheating (temp rises above normal to about 3/4 on the temp gauge and then drops back to normal). I replaced the thermostat, water pump, and expansion tank in succession trying to find the problem. I tested the ETC and it's ohms readings were within range so I didn't replace it. Before replacing the radiator I decided I'd do a compression test. Each cylinder was 150-160#. Ruling out a head gasket leak I went ahead and replaced the radiator. For good measure I replaced the spark plugs as well. I tried starting it after the compression test, new plugs and new radiator and it sounded horrible and wouldn't idle. I turned it off and checked everything and then tried again but the same thing happened. After a couple more tries it simply wouldn't start.
I tested the spark at each coil pack and only cylinder 2 has a spark. I swapped coil packs and the same thing, only cylinder 2. I've check the resistance at both the crank and cam sensors and they appear to be within normal range. I am baffled. I swapped the ECM with a used ECM of the exact model (from ebay). Still won't start. Is it possible the timing chain somehow skipped a tooth during the compression test?
Any suggestions will be greatly appreciated.
Thanks in advance.
Thanks in advance.
I've been dealing with my 2004 Hyundai Sonata and was doing different check up occupations; brakes, flash attachments, start loops/curl packs. In any case, I ran into an issue when I chose to flip one of the loop packs with another in light of the fact that I was getting a "Chamber 2 Failure to fire" code and was checking whether that would fix it. That day, my vehicle wound up kicking the bucket totally and it would wrench yet wouldn't start. I took it over into the shop, verified whether the curls/flash fittings would start and there was nothing. We snared the OBD scanner again and it read "Camshaft Position Sensor." The Chamber 2 discharge failure code left, however now my vehicle won't run. Is there a fuel cutoff valve or something? I've searched for one, yet investigating and glancing through my vehicle, there's nothing. I had a go at supplanting the camshaft position sensor, however without much of any result and it seems like my fuel siphon isn't running. By and large, you can hear the fuel siphon, however I can't hear anything.
snaptube vidmate
snaptube vidmate
