2005 hign beam voltage 10 VDC
Old Dec 18, 2025 | 03:17 PM
  #11
jansport4085's Avatar
Are you using resistors? The LED bulbs draw less power than the halogens. That will cause the LED to dim or flicker.
Old Dec 19, 2025 | 09:09 AM
  #12
You will need this in order for the brights and DRL to work properly. I have a 2006 Camry and had the same issue. This is what I had to purchase. Hope this helps.
https://allalighting.com/products/90...l-off-flashing
Old Dec 23, 2025 | 04:02 PM
  #13
sundy58's Avatar
I originally had halogen and they were very dim. The voltage supplied to the high beam is not 12 VDC when it should be. I replaced the headlight assembly and changed the low beam bulb to LED. They are sufficiently bright that I might not mess with the high beams any more. I drive with my headlights on all the time so 'daytime running lights' are not an issue. I adjusted the new bulbs in the new assembly and have not had a single high beam reminder from oncoming cars. We no longer have vehicle inspections in Texas so that is not an issue.
Originally Posted by sundy58
My high beams are very dim and the blue light indicator on the dash does not light. All the other lights, front and rear operate normally. I measured the voltage at the socket and it only 10 VDC. The relay has 12 VDC for the coil operation. I have not figured out how to check the voltages on the contacts. Help!
umdaman
Jan 18, 2024 11:17 PM
Granpa49
Dec 15, 2017 12:12 PM
beurling
Aug 24, 2013 04:03 PM
egarci10
Jul 17, 2011 05:10 PM
