5sfe crankshaft question
Old Feb 26, 2009 | 12:36 PM
70rrclone's Avatar
Default 5sfe crankshaft question
how do you remove the balance gear from the crankshaft.
thanks
shane
Old Feb 26, 2009 | 01:20 PM
If you are talking about the gear on the crank not sure it can be removed.
Old Feb 26, 2009 | 01:23 PM
70rrclone's Avatar
yes, its the one attached to the crank. some of the replacement cranks say to remove ond
gear and install on new crank.
shane
Old Feb 26, 2009 | 01:32 PM
pedro's Avatar
shane
Do you mean the crankshaft pulley/harmonic balancer?
Old Feb 26, 2009 | 01:39 PM
70rrclone's Avatar
no its the gear at the #2 or #3 crank journal (i dont remember which) that drives the balance assy.
shane
Old Feb 26, 2009 | 01:41 PM
Have seen this also but don't know how it comes off.
Is the crank out now. Any screws, bolts, etc.
The crank is one solid piece. The gear would need to come apart into two sections, it could never slide off.
Not all cranks are set up to receive the gear, assuming it can be removed and transferred. If transferring make sure the new crank is designed to accept the gear.
The number of teeth on the gear may have been changed around 1994 to quiet gear noise.
Old Feb 26, 2009 | 05:24 PM
pedro's Avatar
My FSM shows the gear but does not discuss how to remove it. The crankshaft is cast and machined as one piece so if the gear is not a two piece then you'll need a new crankshaft to fix it. Got a picture?
Old Feb 27, 2009 | 01:08 PM
Would concur, but have seen the statement about transfering over the gear to another crank. And that the new crank must be setup to take the gear.
Old Jul 14, 2009 | 08:27 AM
scelza's Avatar
Post Solution:
Yes, the gear does come off. I just had a local machine shop press it off. Even though it's 6" or so in diameter, it's only 1/2" thick, and maneuvers its way off and on the crankshaft.
To put it back on, the shop heated it up to expand it. They mentioned that you don't want to heat it up too much, or it would lose its tempered characteristics. Didn't follow up on that, but it makes sense.
So, long story short, take it to your machine shop. They may need to get creative to press it off, but it can be done. It cost me $40.
70rrclone
Apr 15, 2009 12:06 PM
0ldcar95
Mar 3, 2009 11:45 AM
vincent52100
Oct 10, 2008 06:07 PM
jeff8428
Sep 29, 2008 08:43 AM
jimmygreen86
Jun 14, 2008 11:09 AM
