92 camry not starting
Old Feb 1, 2007 | 09:07 PM
  #11
smrx8's Avatar
Default RE: 92 camry not starting
I having the same problem 1992 camry was acting and ideling funny and now it cranks and floods itself .change the temp senser ,air filter,gas.,and still nothing [&o]
Old Feb 2, 2007 | 01:42 PM
  #12
geokor's Avatar
check coil, you mentioned it but you didn't say if you tested it. only that you have weak spark and that is usually due to coil.
Old Feb 7, 2007 | 07:41 PM
  #13
tim96460's Avatar
You did a tune up but no cap, rotor or wires???? In cold weather it takes a lot more spark energy to start the car. Check the resistance on your wires which should be around 6k-10k ohms.
If after the above and it still runs like crap I would check to make sure the cold start injector and the other injectors are not leaking or otherwise damaged.
I make sure I run some sort of Techrolene(spelling?) which is found in Chevron gas products or dump some in bouht at the parts store just to make sure the injectors stay clean and carbon build up stays gone, good luck
[align=left] [/align]
Old Feb 25, 2007 | 01:25 AM
  #14
JORTIZ's Avatar
i think this bit of info may help you.in the bigging my car didnt start my plugs were soaked in gas.my spark seem weak.so i spent days trouble shooting then i said let me check the timming and it started right up.its very easy to do.for 114 dollars at auto zone you get a kit.remove your belts the one motor mount passenger side upper bracket.remove timming chain cover upper and lower.remove crank puller.loosen adjustment pully should be right by your cam pulley.and replace belt manke sure you cam is set theres a hole should face straght up theres a mark on the back cover.rotate the crank by hand until the number one piston is completely up tdc top dead center.now your rotor should be faceing about 40 after like a clock that should line your number one spark plug wire.if theres anymore info be more then happy to help you can email me at joseortiz28@optonline.net.good luck.BEFORE ALL THIS YOU SHOULD CHECK THAT IT IS OFF FIRST.
Old Feb 25, 2007 | 01:29 AM
  #15
JORTIZ's Avatar
check timming
Old Mar 1, 2007 | 08:45 AM
  #16
Good Times's Avatar
Had the same problem.---One or two bad plug wires, add a new rotor and distributor cap.---Bet it will run fine then.--You were just compounding the problem by flooding the engine.
Old Mar 1, 2007 | 08:49 AM
  #17
Good Times's Avatar
If you never changed the plug wires before, the heat has deteriorated them. Change them for sure. they break easily within the casing from getting brittle.
Old Mar 18, 2007 | 01:01 PM
  #18
Dermont's Avatar
I have a similar issue, but it gets even stranger than that. About 3 days ago, my 92 camry le (2.2 ltr) started to skip. Fearing that the timing had jumped I switched it off immediatly. Got it back to the shop checked the timing. No problems there. While I had it in the shop I went ahead and did a complete tune up, Changed distributor cap, rotor, plug wires, plugs, timing belt, water pump, pcv valve, and such. Motor still doesn't start. I checked and I got spark. Pulled the plugs and my motor is flooded with gas. I cleaned my old plugs and put them back in, and the motor tries to start, but gives up. I let off the starter and the motor begins to diesel running backwards! It even blows exhaust out the breather.
I rechecked the timing and this happened again. I was about to give up and before I left it lastnight I turned it over and it started it up fine. I want to know what's going on before this happens again so please help me too.
Old Mar 18, 2007 | 04:56 PM
  #19
toyoboy's Avatar
when you guys replaced your igintion rotor did you remove the cover for the coil.and inspect for cracks and short...if thats ok test your temp sensor (alot of them short to ground..)..then test your tps (it could be sticking wide open which will dump fuel and screw timing...) hope this helps some of you.
mk4man
Jun 22, 2009 02:42 PM
almeece
Feb 16, 2009 07:32 PM
rubs
Nov 17, 2008 05:59 AM
itssnowing
Feb 7, 2007 11:39 PM
coolmanlg
Apr 10, 2006 06:49 PM
