93 Toyota Camry V6 constantly ticks.
Old Apr 10, 2011 | 08:22 AM
DefconX5's Avatar
Default 93 Toyota Camry V6 constantly ticks.
I have a 93 Toyota Camry V6, 5-speed manual. It has a constant ticking sound. I have already verified that the oil is there. The oil was recently changed. What is the cause of this?
Old Apr 10, 2011 | 09:55 AM
A ticking noise is often caused by the preset clearance between the cam lobes and valves.
Use a section of hose as a stethoscope (something like garden hose will do) to narrow down the noise location. Listen at the valve covers, passenger side, upper middle and lower part of the engine. Plus any component driven by the "V" belts.
Old Apr 10, 2011 | 02:26 PM
DefconX5's Avatar
Is there any way to fix the problem?
Old Apr 10, 2011 | 05:39 PM
Find out the area of the noise.
If from under the valve cover the valve clearance can be adjusted.
97camry209
Mar 24, 2012 11:14 PM
darimura
May 18, 2011 09:09 PM
tazm01
Sep 2, 2010 08:57 AM
bullisbm
Dec 9, 2008 05:07 PM
