94 camry v6 random stalling
Old Dec 7, 2011 | 01:13 PM
  #11
94camryle's Avatar
Thanks!
So far the cleaning the IAC valve did the trick, have not had any probs since. I do use the spare key.
Even though Its not stalling now.
I still would like to check the ignition switch to rule it out for sure but I cant find any diagnostic charts for properly testing it. Does anyone know where i can find free info for testing and diagnosing the ignition switch circuit?
Old Dec 7, 2011 | 07:05 PM
  #12
No sure how to test the switch, it either on or off.
The portion of the ign switch powering the ign system also powers the injectors, fuel pump relay, O2 sensors and a few other items.
If the car stalls check for power at the coils and injectors-Black/Orange wire.
Old Dec 7, 2011 | 11:40 PM
  #13
93fixerupper's Avatar
Get the voltage regulator tested first. It sounds like you might have an expanding short in it. it would close if the electrical system cools down, then open back up when it 's been running. Also check all connections to the firing system (plugs, coils, etc.) the same type of short could be present there.
Old Nov 8, 2012 | 08:03 PM
  #14
94camryle's Avatar
After doing every diagnostic test possible I found the culprit was a bad ECM.
Solution: replaced ECM.
problem solved.
Old Jul 31, 2021 | 01:10 AM
  #15
MegMorg161616's Avatar
Default Outcome?
Originally Posted by 94camryle
any suggestions are welcome!
outcome of your stalling issue?
im having same issues
Old Aug 8, 2021 | 10:47 AM
  #16
Default Crank shaft sensor or igniter. Mine was igniter. Need one badly
Need igniter. Not crank shaft sensor
CamrySunroof
Nov 18, 2011 08:39 PM
mannyolicious
Oct 27, 2008 12:58 PM
mannyolicious
Oct 27, 2008 12:05 PM
Geology Rocks
Oct 24, 2006 03:35 PM
dmend
Jul 5, 2006 01:24 PM
