98 Camry Dome Light Not working
Old Nov 4, 2017 | 06:19 PM
deface666's Avatar
Default 98 Camry Dome Light Not working
I have replaced the bulb and the fuse on my dome light and it still isn't coming on. If it is a wiring issue, where would i even look/start? I unscrewed the four screws up top also and made it sure it was connected there which seemed fine.
Old Nov 4, 2017 | 07:47 PM
Check if the dome light his getting power. The switch grounds the wire from the bulb to turn it on.
Old Nov 4, 2017 | 08:35 PM
deface666's Avatar
How do I do that exactly? I saw the old one flash on for a second when I took the bulb out but didn't stay on
Old Nov 4, 2017 | 11:34 PM
Obtain voltmeter.
Check for battery voltage at bulb the socket contacts. One contact should have battery voltage.
The other terminal would then run to the switch. This terminal should then ground when the dome switch is turned on.
felixtibs
Feb 27, 2020 12:57 PM
numbersguy
Oct 24, 2010 04:33 PM
floridarider
Oct 11, 2010 10:37 PM
floridarider
Oct 10, 2010 10:01 PM
ll5175
May 21, 2008 08:37 PM
