AC not working
Old Mar 9, 2006 | 02:07 AM
2003camry's Avatar
Default AC not working
I own a 2003 Camry LE,recently my AC became unserviceable and I have been to a few repair shop and all of them just can't fix the problem for.Whenever I try to on the AC switch,it will just flashes at me with no cold air out.Some mechanic told me its because of a leak in the system while others said it is a due to a problem relay in the switch.Has anyone out there encounter similar situation,please advise me,thanks in advance...
Old Apr 4, 2006 | 08:42 PM
marc780's Avatar
Default RE: AC not working
Id try bypassing the switch. Remove the switch, disconnect the wires and connect the wires together with a jumper wire and see if your AC comes on.
It flashes so the switch is probably getting power. But also check the wires going to the compressor at the engine and see if they are getting power. (Youd use a multimeter or vom to check it for power, theyre cheap and easy to use).
Old Nov 25, 2006 | 10:54 PM
toyotaadvisor's Avatar
it is your magnetic clutch relay.
Old Feb 11, 2008 | 01:09 PM
clueless314's Avatar
I have the same problem and gave up several years ago. I just wondered if this persons problem was resolved, and if there's hope for me to try, yet again, to have a working AC.
Old Feb 11, 2008 | 06:54 PM
Toyota has a Technical Service Bulletin stating it could be the magnetic clutch relay. Check the P/N, if 90987-02022 replace with 90987-02028.
rloveys
Dec 11, 2007 05:46 AM
vtd
Oct 6, 2007 11:57 PM
mrpackrat
Dec 26, 2006 10:16 PM
StikiGreenZ
Nov 18, 2006 11:31 PM
josephpatrickgray
Jan 25, 2006 08:30 PM
