Battery went dead
I have a 2012 Toyota Camry SE. I left my head lights on all night and the battery went dead. I have charged the battery. The car can start but I notice on the dash board the Low tires pressure light and the ABS light. The outside temperature it has a E. The radio and the climate console and clock will not come on. Last but not least I can't put the car out of park. Has anyone experiance this. Please help Thanks.
Where there any problems in charging the battery?
Suggest start by checking for blown fuses.
If you need to drive there is a manual trans shift lever bypass.
The owners manual should have information on fuse locations and trans shift lock bypass.
Yea. No problem charging the battery? I can bypass the **** lever. But when car is started. There no power to the power steering and what I mention on the the thread. fuse are good. I hate to do it. but look like i will have to it to the dealer. I will keep you posted. Thanks toyomoho
It various lights are on, a trouble code(s) may have been stored.
Find someone with a scanner who can read the codes, then clear them. Then determine if they come back (lights come back on).
The battery charge may have damaged some electrical components.
