Camry wont start
Old Mar 21, 2023 | 06:45 PM
mechman's Avatar
Default Camry wont start
Hi, I have a 09 Camry 2.4 that wont start. It 57 psi fuel pressure, spark and injector pulse. It almost wants to start but then doesn't. Can someone help me?
Old Mar 22, 2023 | 01:00 PM
Did the engine ever run? Any repairs done prior to this problem?
Old Mar 22, 2023 | 10:39 PM
mechman's Avatar
It has low compression in all cylinders I just found out numbers are 95-97-48-107
Old Mar 23, 2023 | 02:44 PM
Are you sure the 48 psi reading is accurate?
Old Mar 23, 2023 | 04:05 PM
mechman's Avatar
I put oil in the cylinder and got it to 87 psi, but I think it's still too low for combustion.
Old Mar 23, 2023 | 07:55 PM
Around 100 psi is supposed to the minimum.
Make sure the EGR valve is not stuck open, no major intake air leaks, exhaust system not plugged as in converter. Is the fuel too old and bad?
Old Mar 23, 2023 | 11:04 PM
mechman's Avatar
It won't even start on starting fluid with fuel relay removed. No leaks or plugs either. EGR is closed.
Old Mar 24, 2023 | 08:32 AM
What is the history of the car? Did the engine just quit one day and the car was parked. The low compression then found later but perhaps not related to why it quit.
Is the starter motor rotating the engine at normal RPM’s? Is the ign timing correct? Any trouble codes stored or pending including Toyota codes. A bad crank/cam sensor can cause starting issues.
Jrwood
Feb 15, 2022 10:42 PM
redtree
Jul 12, 2011 06:20 PM
brandon_bauer
Jun 18, 2010 12:46 PM
ThaiCamry97
Dec 29, 2006 12:12 AM
rtullar
Oct 18, 2006 04:25 PM
