Hand Break light is on and off.
Old Jul 31, 2020 | 03:23 AM
Akinlo Taiwo's Avatar
Default Hand Break light is on and off and speedometer stops working when the light is on
I am using Toyota Camry 2007. I discovered when the car is in parking mode or in motion the hand break light will be on and off. Whenever the hand break light is on the speedometer will stop working. However, when the hand break light is off, the speedometer will starts working immediately. What is the problem and the consequences of this on the car? Thanks
Last edited by Akinlo Taiwo; Jul 31, 2020 at 03:32 AM. Reason: To add more information
Old Jul 31, 2020 | 03:02 PM
Is the hand brake light coming on without applying the hand brake?
Does the car have ABS and if so is this light coming on?
Old Jul 31, 2020 | 05:09 PM
Yes, the hand brake is coming on while in motion. The car has ABS and the light of ABS is always on when the engine is on.
Old Aug 1, 2020 | 12:44 AM
Check for ABS trouble codes. Could be a bad ABS sensor. You will need an OBDII scanner that can read ABS codes.
GM_Firebird1967
Oct 19, 2017 02:41 PM
Doiche
Jan 29, 2013 01:42 AM
James67
Jan 27, 2010 10:20 PM
Camrydriver
Oct 1, 2008 08:47 PM
green giant
Feb 19, 2006 04:29 AM
