I need HELP
Old Jul 10, 2008 | 10:23 AM
  #11
chicknhawk1999's Avatar
Default RE: I need HELP
Ok ill try a few of these things tonight, if you have anymore ideas just let me know. Thanks
Old Jul 10, 2008 | 09:50 PM
  #12
trd_camry's Avatar
Could be fuel or spark issue, but really Ileaning towardit being air related. Either the MAF sensor or a faulty catalytic converter . Hopefully when you get this resolved you can share what the issue was, to help others in the future.
Old Jul 11, 2008 | 06:24 AM
  #13
pedro's Avatar
I've had the same issue of limited rpm and bucking but it only occurred when in gear under load. In one case it was a bad coil and in another fuel starvation. If you have a vacuum gauge then it could help find an exhaust restriction.
Normal idle vacuum is 17-20hg and it should fluctuate to about 2hg to 25hg as you depress the gas pedel and release. For an exhaust restriction start with idle and slowly increase speed to 3000rpm, engine vacuum should be equal to or higher than idle at 3k rpm. If vacuum decreases at higher rpms there is excessive back pressure.
If you have access to a chassis dyno reproducing the condition with an engine computer hooked up makes it easier.
Old Jul 11, 2008 | 08:20 PM
  #14
trd_camry's Avatar
Vacuum leak is a good possibility too (again air)
Old Jul 12, 2008 | 09:53 AM
  #15
elsie92xlev6's Avatar
yea i agree with the guy above it has to be air related especially if u just got parts of ur fuel system repaired, check ur vacuum hoses to see if they r dirty seafoam can always clean them out if u want a quick cheap possibility
rlmeredith
Aug 21, 2012 07:33 AM
sv21
Apr 30, 2009 12:52 PM
ToyotaMan55
Jun 6, 2006 01:51 PM
SymtecX
Feb 27, 2006 03:00 AM
cam03TRD
Aug 21, 2005 06:55 AM
