Motor oil
Old Jan 25, 2016 | 07:13 AM
  #11
reynoldston's Avatar
Originally Posted by wdc123
I no longer push my car like I use to( Contour SVT). Blowing front bearings a few times. No fun pulling steering knuckle out, having the bearing pushed out and a new one installed. then reinstalling knuckle. What happened to the good old days where you could pull the bearing out and repack. Sorry off on a tangent but just reminiscing.
I must be a little older then you and made my living as a mechanic. I am going back to my drag racing days when I was running small block Chevrolet engines with a 4 speed manual transmission or the two speed power glide trans. Any of the engines I ever worked with had bearing inserts. Unless we go way back as I recall the old stove bolt 6 cylinder Chevy engines has poured bearing with shims to adjust them. Now I am going back into the 1930's and 40's. I do remember working on a few old Ford V8 flat heads engines that was in the late 40's early 50's but didn't they have bearing inserts also? The only thing I can ever remember repacking in them old engines was the rope style rear oil seals and they leaked oil no matter what you did.
Old Jan 25, 2016 | 10:28 PM
  #12
wdc123's Avatar
Sorry I was talking about front wheel bearings in my dads 1970 impala, back in the day. Not engine. Easily removal, clean, pack , reinstall.
Old Jan 26, 2016 | 05:33 AM
  #13
We are talking about front wheel bearings. Ok now I understand. Lets get back to Toyota. They are sealed bearings that should never need replacing our ever need maintenances. One of the many great things of the newer cars of today and the reason to own a Toyota.
Old Jan 26, 2016 | 11:48 AM
  #14
Improvements in cars, tires, etc is great thing.
Improved comfort, safety and performance with less maintenance, all while getting much better MPG and having a longer service life.
Occasionally I drive cars from the 50's and 60's and this just reinforces how much things have improved.
Old Jan 26, 2016 | 02:02 PM
  #15
wdc123's Avatar
SS exhaust, Tune up every 100k, not 10 k, steel belts no 4 ply tires, no pumping brakes when sliding, and on and on. Oh seat belts.
indiglofish61
May 17, 2015 08:23 PM
indiglofish61
Apr 29, 2015 04:51 PM
Mark DiSilvestro
Nov 5, 2013 09:12 PM
NCcamry98
Jun 24, 2008 08:00 PM
rdblais2000
Jun 29, 2007 02:30 AM
