no power to windows,radio, trans is locked, and starter will not turn.
Old Feb 26, 2018 | 04:58 PM
chuckklr98's Avatar
Default no power to windows,radio, trans is locked, and starter will not turn.
starter will turn over if relay is jumped, replaced relays, still no power. all fuses are good. no power to trans shifter, have power to radio fuse.
batteries is hot
replaced ignition switch wiring assembly. still nothing
at wits end
Old Feb 26, 2018 | 10:08 PM
Did you check the AM1 and ALT fuses?
Old Feb 27, 2018 | 04:31 AM
chuckklr98's Avatar
every single fuse has been checked
Old Feb 27, 2018 | 12:06 PM
It appears the starter solenoid circuit has a problem. Plus power to the trans shift lock. The fuses and circuits that power these items also power a lot of other circuits. Besides the shift lock, what works and what does not?
If engine turns over when, assume the start relay, is jumped. Then the relay switch circuit is OK.
The ign switch is two switches gained together. The AM2 circuit (powered by AM2 fuse) powers the AM2 side of switch.
With ign which on check for power at black/red wire of ign coils, cigarette lighter and stop light.
HavinaPretzel
Dec 7, 2013 11:12 AM
Scrumpilump2000
May 24, 2013 09:54 AM
linsjean
Apr 6, 2012 08:55 AM
veteranschoolboy
Oct 14, 2011 10:09 PM
DLW
May 24, 2011 10:31 AM
