oil pressure guage
Old Nov 1, 2007 | 06:16 PM
montanacb7's Avatar
Default oil pressure guage
i have a 93 with the 5sfe and was wondering where the best place to install an oil pressure gauge would be. is there a secondary port for the gauge or if you need to install it at the oil pressure sending unit.
also where is the sending unit located.
Old Nov 2, 2007 | 04:56 PM
pedro's Avatar
Default RE: oil pressure guage
I installed a mechancial gauge on mine because the sending unit is small and fits well with the exisitng sender. The sending unit is tappedinto the right side of the head facing front. I would recommend keeping the existing sender and use a "T" fitting to install an aftermarket gauge. You will need a BSP to NPT adapter to install the "T" and keep the existing sender. AutoMeter gauges carry the adapter and some good mechanical/electric gauges.
This is a good DIY:
http://www.toyotanation.com/forum/sh...d.php?t=208743
Old Nov 3, 2007 | 12:25 AM
montanacb7's Avatar
thanks thats a lot of help.
pmaharana
May 3, 2013 10:26 AM
beetlespin
May 9, 2009 05:01 PM
william
Feb 4, 2009 06:40 AM
motor822
Jul 9, 2007 07:35 PM
