Question on this '87 for sale, injectors wont fire
Old Aug 21, 2016 | 04:21 PM
g3bill's Avatar
Question Question on '87 2.0 for sale, injectors wont squirt
This probably is a bad deal? The '87 2.0 4cyl wagon is a silver LE with alum wheels, sunroof and interior looks good, its got 200,000mi. A/C compressor was removed and long gone, maybe the brackets also, the guy wasn't sure.
Any way, it wont run but said it did when parked. He changed the fuel pump but injectors wouldn't squirt. He said it has spark. The wagon's been sitting for about 8 years outside and engine has corrosion on surfaces that i can see in pics.
Q
Any ideas as to why injectors wouldn't spray. He thinks electrical like a bad wire, i'm thinking computer, and if so where should we look. Does this sound too thick to get into....
Wonder how long I'd have to wait to find a perfect one of these equipped with the goodies I like?
Old Aug 22, 2016 | 02:44 AM
dirty hands's Avatar
unless it was given to me free
i would walk away from this one
sitting for 8 years mean issues ......will need a complete full going over and fluid service
200000 km is getting high .....will need timing belt
no air con is expensive to re fit and gas the system back to factory
injector issue
could be a
relay or fuse or something simple
or
bad ecu (computer).if so .as an import hard to source a used one that is the correct ecu for the model
to check injectors
needs a pulse tool to check if the injectors are getting any current
Old Aug 22, 2016 | 10:57 AM
g3bill's Avatar
Lightbulb another question
Thanks for your input dirtyhands . reminds me got to get some hand cleaner. I might go see wagon tomorrow, its about 40 miles away
I know theres a safety relay or the like that shuts off the fuel pump if motor stalls, could that also shut off the injectors. If motors not running its not pumping gas, right. There should be a way to jump connections in the fuse box to bypass that safety circuit , any thoughts
Old Aug 22, 2016 | 10:00 PM
i wonder if stale fuel is the reason for no start
if the engine light is on when you are cranking the engine
the ecu computer will have stored fault codes
https://www.engine-light-help.com/to...ine-light.html
if no engine light then its a simple fault
try some off the shelf " start you mug " spray into the throttle body
to see if the motor wants to try and run
this model does have a fuel relay
as you turn the key you should be able to hear the noise of the fuel pump pumping
Old Aug 22, 2016 | 11:23 PM
The pump will only run when the engine is cranking over or running.
Find a small plastic box on the passengers side of the strut tower. Then inside the box jump the B+ and FP terminals. This will allow the pump to run when the ign switch is on.
Old Aug 23, 2016 | 06:27 AM
g3bill's Avatar
Thumbs up
Thanks for the link dirtyhands and toyomoho you always have the answer
Bill
mindle374
Sep 21, 2010 10:56 AM
brianjrealtor
Jun 24, 2010 09:18 PM
ddyke2000
Jun 10, 2009 02:35 PM
eikon
Nov 7, 2007 11:19 AM
feral68
Dec 29, 2006 08:07 AM
