warning light for brakes is on . . .
Old Sep 19, 2008 | 10:42 AM
Octapulse's Avatar
Default warning light for brakes is on . . .
. . . but all my brake lights and turn signals are working fine. Anyone know what is going on?
side note: the light came on once about two months ago after I had a spoiler with a tailight installed, but the next time I shut off the car and re-started the engine, it went away.
Old Sep 19, 2008 | 11:07 AM
Default RE: warning light for brakes is on . . .
What year of car. Was this a Toyota OEM spoiler, did it have a LED or filament light.
Old Sep 19, 2008 | 11:51 AM
nodrogkam's Avatar
Just to make sure...the light that is on your dash isnt lit up in red and spells out BRAKE? right? haha.
You're talking about the yellow colored one with rays of light extended off the back of a "trunk" right?
If the spoiler has the proper resistor installed to compensate for thelow power draw of LED's your computer should not recognize any bulbs are out. Double check all your bulb connections...jiggle/wiggler them and see if that helps.
Otherwise there could be an issue with the LED's in your spoiler.
Old Sep 19, 2008 | 01:52 PM
pedro's Avatar
"...when you could rule it with a led foot?"
Shouldn't that be "lead" foot?
Old Sep 19, 2008 | 02:56 PM
PyrMan3's Avatar
check your fluid resivor, its probably the led strip
Old Oct 15, 2008 | 08:23 PM
muminiasty's Avatar
What was funny in my 97 toyota that front light was dead but back light light was on. I guess there is no front light sign on the clocks
Old Nov 5, 2008 | 02:00 PM
ussearch's Avatar
Octapulse, did you figure out what it was? I've had a similar problem with my Corolla, and the light comes on periodically for no apparent reason (that I know of at least).
Old Nov 5, 2008 | 11:31 PM
Check brake fluid level, brake fluid level switch and E-brake switch.
weez
Sep 29, 2018 01:30 PM
LeeM
Oct 2, 2011 10:54 PM
Camrydriver
Oct 1, 2008 08:47 PM
green giant
Feb 19, 2006 04:29 AM
CKSAMartin
Dec 16, 2005 02:24 PM
