Camry 2.4 ACV30 transmission problem
Old Dec 2, 2022 | 02:44 PM
Bata Roger's Avatar
Default Camry 2.4 ACV30 transmission problem
The gear is not engaging, even I switched off the engine and put it to neutral and tried to push the vehicle it can't move backwards it's only moving forward. What would be the cause?
Old Dec 2, 2022 | 03:29 PM
Is the shift lever on the transmission moving with the shift lever and if so in sync with the selected gear?
Old Dec 2, 2022 | 05:57 PM
Bata Roger's Avatar
Yeah I tried that already, the shift leaver is moving.. the gear cable is okay, transaction between the leaver and gearbox is okay but the vehicle can't move backwards or even forward when accelerating on drive or reverse.
When switching off the engine, put gear to neutral and tried to push but it can't move backwards, it's only moving forward.
I think the problem is inside the gearbox but what exactly could it be?
Old Dec 3, 2022 | 11:50 AM
Jack up the front of the car one side at a time. With trans in neutral, and try to rotate the tire now off the ground tire in each direction by hand.
dangler
Sep 15, 2022 02:03 PM
Humphery
Aug 4, 2021 06:23 PM
Christi
Jul 25, 2020 08:49 PM
Mario Rossouw
Dec 5, 2018 10:43 AM
Nick G
Jun 26, 2012 10:30 AM
