car will not start after replacing ...
Old Jan 30, 2012 | 06:03 PM
mikel's Avatar
Default car will not start after replacing ...
1996 camry 4 cylinder
Replaced -
Ignition coil
plugs, wires
starter
battery
battery cables
Still nothing. I have power to the car but no crank, no turnover?
Old Jan 30, 2012 | 09:28 PM
full house's Avatar
are you use you got enough Gas to power it up?
Old Jan 31, 2012 | 09:18 AM
The engine does not crank over when you turn the ign key to start?
Obtain one jumper cable. Clamp one end over the positive battery cable terminal and carefully touch the other to the electrical terminal on the starter solenoid that goes to the starter motor. If the engine cranks move the cable end to the other side of the solenoid and have someone turn ign key to start. If start motor works check battery cable going to the starter solenoid and starter relay circuit.
The small wire going to the solenoid should have 12 V DC when the ign key is turned to start.
Or does the engine crank but does not start? If so check for ign spark at the plug wires.
Lou
Jul 1, 2017 03:02 PM
Dougiej
Apr 27, 2014 04:58 AM
dhabu02
Jun 14, 2013 05:30 PM
Texavant
Aug 18, 2012 11:39 AM
