2018 Camry SE amp/sub install
I know on the XSE/XLE, there is a stock sub and upgrade to the entire sound system. I have the SE, and am wondering if the stock head unit has RCA outputs? If not, does anyone know of any plug and play wiring harnesses made for the 2018 camrys that I could use to install an amp/sub?
A line converter can tap directly into the LA-G/LA-R etc, wires. The converter reduces their signal strength and outputs it via a RCA plug.
Some amps have two inputs sources, a RCA and a line input. In this case can connect the speaker wires directly to the line input of the amp.
Do some research on amps. Crutchfield.com is a good source.
RileyJSchmidt
Aug 17, 2014 11:52 AM
xNOxSK1LLZx
Feb 24, 2009 10:38 AM
