Steering Problem has Auto Guys Stumped
Old May 7, 2019 | 10:31 PM
Melk's Avatar
Default Steering Problem has Auto Guys Stumped
Hi. Hoping for advice on my Camry Sportivo 2006.
Had a faulty steering column intermediate shaft replaced one year ago. After this a grinding noise began in the steering when turning hard left, say when parking. The Auto guys are friendly and helpful, but haven't been able to work out the problem. When they investigate, it comes good for a few days then the grinding noise returns. I was wondering if:
  1. The new steering shaft wasn’t installed properly.
  2. The new steering shaft installed was a faulty item.
  3. Damage was caused while the steering shaft was being replaced.
Or any other advice would be appreciated. thanks in advance, Melk
Old May 7, 2019 | 11:06 PM
Grinding when turning the steering wheel or grinding from a tire wheel?
Old May 8, 2019 | 02:10 AM
Melk's Avatar
Thanks for your reply.
The grinding is when turning the steering wheel. The noise seems to kick in when the it is turning towards its furtherest point. The noise can be felt in the steering wheel.
Old May 8, 2019 | 09:48 AM
Get a section of rubber hose and find a helper. Have this person rotate the steering wheel towards the farthest point while you listen to the steering shaft using the hose as a stethoscope. Try to narrow down the location of the noise. Also listen to the power steering pump and the upper strut mounts in case they might be the cause.
Could it be the shop is spraying lube onto the area of noise and this is temporarily solving the issue?
Old May 8, 2019 | 05:01 PM
Melk's Avatar
Hi Joey P, Thank you … That's a good suggestion.
And yes, I think this is the case. They've looked at in about 4 times, and it is fixed for a few days, then the problem returns.
Old Feb 28, 2025 | 03:22 PM
Bugman-T's Avatar
Default Squealing power steering pump
There seem to be two different problems described. Squealing when you turn the wheel back and forth the full path sounds like the power steering pump or belt. What shape is the belt in. Have you changed the fluid? Is it topped off? To bleed the pump turn the wheel back and forth from stop to stop. Creaking noise when turning it back and forth (especially strong at the extremes) could likely be a strut bearing. I recently replaced my strut assemblies and the bearings were shoddy despite the struts being a name brand.
joshy4444
Aug 19, 2021 12:22 PM
jmarcum1968
Dec 12, 2018 05:21 PM
bas
Nov 8, 2013 07:01 PM
swataz
May 7, 2007 10:58 AM
Leonard15
Nov 25, 2006 10:34 PM
