2012 Camry engine turns, will not start
Old Dec 20, 2018 | 01:30 PM
BerFit's Avatar
Default 2012 Camry engine turns, will not start
Our 4 cylinder Camry, with 75000 miles, will spin the engine but doesn't start. Any help is appreciated.
Old Dec 20, 2018 | 11:07 PM
Check for ign spark when turning engine over.
Do you have another ign key? If so try it.
Old Dec 24, 2018 | 11:11 AM
BerFit's Avatar
Tried another key, same problem. Sounds like the motor speeds up a little while cranking. I didn't know how to check for spark with the coils being directly over the spark plugs. The positive battery terminal was covered with white powdered stuff, so I removed both clamps, cleaned battery posts, charged the battery and replaced the positive terminal. Had my wife crank the car while I sprayed starting fluid into the filter housing. No start. I tried cranking while holding the accelerator pedal down, and the engine ran. All I have done is clean the battery posts, replace corroded terminal and charge the battery. Toyomoho, thanks for the good advice.
Old Jul 30, 2022 | 07:50 PM
nhantech's Avatar
Hi, seems like I’m having the same problem you had. After I disconnect the battery terminal and reconnect it everything works fine until the next episode. No codes or anything of that nature. Long shot but did you ever fix the car?
Old Aug 2, 2022 | 04:16 PM
BerFit's Avatar
Soon after cleaning the battery terminals we went to the dealer for a scheduled oil/lube. Dealer said the battery needed replacing. Battery replaced, no problems for past three and one-half years.
Old Aug 2, 2022 | 09:50 PM
nhantech's Avatar
Thanks for replying. Unfortunately I’m not so lucky. More than like an ecm for me
Dylan Lange
Oct 23, 2016 10:46 AM
shde
Aug 5, 2016 06:15 PM
victorphoenix
May 18, 2014 11:45 PM
Jeffstunts
Jan 3, 2011 08:38 PM
ahadden09
Jul 26, 2010 08:19 PM
