Sponsored by:
Sponsored by:
Camry 200SI starting
Old 01-31-2015, 07:50 AM
JFP's Avatar
JFP
JFP is offline
Default Camry 200SI starting
Hello
Can somebody please help me.
I have a Camry 200 SI 2000 Model. The car does not want to start. The Engine turns over normal once the Immobiliser is activated (I also used the By-Pass in the Boot to Bypass the Immobiliser/Alarm) Engine just turns but no start. Any ideas/advice please, Thank you in advance.
Old 02-01-2015, 12:40 AM
If all electronics are working properly, make sure the engine is getting fuel.
Do you smell gas after cranking the engine over a few times?
Old 02-04-2015, 07:54 AM
JFP's Avatar
JFP
JFP is offline
Thanks for the advice Patonium. The end result was interference from the Anti-Hijack unit causing a Voltage drop to the Fuel Pump.(Low Voltage). Replaced anti hijack unit. Thanks again for advice, much appreciated.
Old 02-05-2015, 12:28 AM
Glad it is fixed! Thanks for posting back.
JanSport40
07-26-2009 07:53 PM
illstreetracer101
03-18-2007 04:56 PM
itssnowing
02-07-2007 11:39 PM
craiggo
06-03-2006 04:20 AM
coolmanlg
04-10-2006 06:49 PM
Quick Reply: Camry 200SI starting
