1997 Camry Neutral safety switch broken bolt HELP
Old Nov 10, 2019 | 05:49 PM
Dan Deremiah's Avatar
Default 1997 Camry Neutral safety switch broken bolt HELP
While replacing a malfunctioning NSS, I sheared the tip off the control shaft. The linkage nut was rusted completely on and took the first 1/4" off with it. Is there anything other than replacing the transmission that can be done?
It's a 1997 Camry 2.2 liter
Old Nov 10, 2019 | 08:49 PM
The shaft the shift lever is bolted to?
If you can find a replacement shaft the job can be done by dropping the trans pan.
If you are clever can drill and tap a hole in the end of the shaft for a bolt.
indiglofish61
May 13, 2015 04:56 PM
mageml895
Jun 26, 2014 11:03 AM
iwantotfix
Nov 18, 2013 10:03 AM
oldad
Dec 31, 2012 01:06 PM
upjeeper
Oct 10, 2006 06:14 PM
