2000 Camry 2.2 stumble at cold warmup
Old Feb 20, 2025 | 02:06 PM
  #11
How fast is "runs fast?"
How sure are you that the IAC valve was fully cleaned?
If the coolant level normal?
Old Feb 20, 2025 | 06:19 PM
  #12
raj86's Avatar
As I mentioned before on cold winter mornings, below 40F, it get realy close to 2000, about 1980 rpm.
before pandemic I fully cleaned iac valve and put new seal on it. As after warmup rpm goes down indicating that it works fine.
what next I should check?
New spark plugs and wires, new air and fuel filter.
Old Feb 22, 2025 | 01:55 PM
  #13
Seldom does the ECU fail on this car.
You state the engine can quit as in turn off then restarts OK?
The coolant has a temp sensor that sends a signal to the ECU. Based on this signal the ICU controls the IAC valve.
Check resistance of:
Ign coils,
Resistance:
Secondary
Cold Hot
9.7–16.7 Kohm 12.4–19.6 Kohm
Resistance: Cold/Hot
Camshaft position sensor
Crankshaft position sensor
835 - 1,400 ohm
985 – 1,600 ohm
1,060 – 1,645 ohm
1,265 – 1,890 ohm
The coolant system has a temp sensor (ETC) that tells the ECU the coolant temp.
Check resistance between temp sensor Green/Black and Brown wires at 176F. Should be 0.29 - 0.354 Kohm.
scasti1
Apr 18, 2022 10:13 PM
World Communications
Feb 21, 2012 07:36 PM
dlockward
Apr 3, 2011 08:35 PM
mail2_jb
Jul 14, 2010 10:15 AM
dangkhoi
Nov 11, 2007 05:46 PM
