2003 Camry 2.4L Composite Gears?
Old Jul 24, 2017 | 12:42 PM
SkyCamRy's Avatar
Default 2003 Camry 2.4L Composite Gears?
My camry went down and was told to purchase composite gears? What exactly are they and where can I get this supposed dealer-only item? I want my car back, any help/info would be appreciated. Thanks.
Old Jul 24, 2017 | 10:05 PM
Composite gears?
What is wrong with the car?
Who told you about composite gears?
Old Jul 26, 2017 | 08:37 AM
SkyCamRy's Avatar
Default Composite Gears
Composite gears?
My 03 Camry went down and the mechanic pulled the oil pan and there were fibrous components that had teeth on it, that resembled gears. IDK if that's the right word to describe these things, but yeah it looked like gears but they looked like they were a composite material.
Old Jul 26, 2017 | 03:38 PM
The balance shaft drive gears are fibrous. They can come apart.
Search the net for 2AZFE balance shaft gears.
Toyota part. Cost approx $141 (left) and $76 (right).
Does the engine still run?
The shafts can be removed and oil supply hole plugged. This may however shorten engine life at higher RPM's due to crank flexing.
Old Aug 9, 2017 | 12:41 PM
SkyCamRy's Avatar
Yes, the engine still ran when the engine stopped working correctly.
I'll look about and see what I can find, you wouldn't have a preferred online vendor for the gears would you?
Thanks,
Karl
Old Aug 9, 2017 | 04:50 PM
Check various dealer online prices as some may be cheaper then others.
Titus-Will Toyota/Scion | Genuine Toyota & Scion Parts
pimppy
Jul 12, 2011 10:12 AM
trunksbomb
Jun 1, 2011 08:06 PM
koolnerd711
Dec 2, 2010 11:49 AM
hepsi
Jan 24, 2010 08:14 PM
