Thermostat, Radiator Hose, and Coolant Recommendations
For my 1989 Camry, my OEM is 180'F/82'C and I'm using a Stant #13578 (originally mistyped as 17538)
https://www.amazon.com/Stant-13758-Thermostat-Degrees-Fahrenheit/dp/B000C7YQP6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1533772626&vehicle=1989-76-1011-269----5-4849--1-1---2-0&sr=1-1&ymm=1989%3Atoyota%3Acamry
How about Stant's SuperStat?
https://www.amazon.com/Stant-45758-SuperStat-Thermostat-Fahrenheit/dp/B000C7YRT6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1533773202&sr=1-1&keywords=stant+45758
Is one brand (Stant vs. Gates) better for thermostat?
Which type of gasket do I need for the thermostat: the thermostat housing o-ring or coolant outlet gasket?
https://www.oreillyauto.com/detail/b/mahle-original-4186/cooling---heating-16773/thermostats-and-gaskets-16977/thermostat-water-outlet-gasket-11350/182cf17298ba/mahle-original-coolant-thermostat-housing-o-ring/c31090/4426106/1989/toyota/camry?q=thermostat+gasket&pos=13
https://www.oreillyauto.com/detail/b/mahle-original-4186/cooling---heating-16773/thermostats-and-gaskets-16977/thermostat-water-outlet-gasket-11350/182cf17298ba/mahle-original-coolant-outlet-gasket/c24184/4426052/1989/toyota/camry?q=thermostat+gasket&pos=12
Same question with brand of radiator hose. I have a Gates upper radiator hose and Dayco (Autozone) lower radiator hose, due to limitations in parts availability.
Finally, do I need to use Toyota OEM coolant, or is aftermarket (Peak?) okay to use?
Thanks
Thanks
Thanks.
I meant Stant Thermostat #13758.
Thanks for pointing that out.
I corrected my original post accordingly, and here's a a link to that thermostat:
