1990 camry 4 cyl . changed fuel filter now car won't start
Old Aug 29, 2012 | 08:09 PM
tight budget's Avatar
Default 1990 camry 4 cyl . changed fuel filter now car won't start
car was running rough so i changed fuel filter.
now car won't start.
engine turns over and if i spray starting fluid
it sputters but won't run.
loosened top nut on fuel filter
and has lots of pressure.
fuel spayed out, so re tightened nut.
checked efi relays and efi fuses
then replaced coil inside distributor
tapped on igniter with small hammer.
still no start.
Old Aug 30, 2012 | 11:43 AM
also. no check engine light
does this mean igniter is shot ?
Old Aug 30, 2012 | 05:22 PM
just tried a new igniter.
no luck.
heading back to buy a distributor
Old Aug 30, 2012 | 06:50 PM
just tried ditributor
model number R0121D04
richporter
G09
874183000696
ty33
kit came complete with new distributor cap and new plug wires.
still no spark.
Old Aug 30, 2012 | 07:33 PM
Have you checked for ign spark at the coil? Remove the coil wire at the dist cap and hold about 1/2 inch from a ground. Check for ign spark.
Check for 12V (ign on) at the coil battery terminal (black/orange wire).
Old Aug 31, 2012 | 12:49 AM
what will this tell me ?
Old Aug 31, 2012 | 11:37 AM
You have replaced most of the ign parts but have checked to make sure the coil is making spark or receiving 12V power?
If the engine tries to run on starter fluid it has spark but no fuel.
Old Sep 7, 2012 | 05:44 PM
took car to shop.
Toyota placed diagnostic reader on car.
code says mass air flow censor has short.
replaced mass air flow censor. and car starts right up.
arggh!
ejmaue
Jan 18, 2010 01:07 AM
anfurnee
Nov 6, 2008 11:55 AM
pbenezra
May 5, 2008 11:28 AM
90Camry
Oct 24, 2007 11:26 AM
62 chevy
Jul 19, 2007 04:22 PM
