96 camry weird issue: obd port, stalls when gassed, need guru
First off. The car is a 96, 1mzfe
Car wont rev past 2000, will stall and die.
Replaced:
New fuel pump
New fuel filter
New spark plugs
Used tps
Used fpr
Used cps
Checked for vacuum leaks
Has a steady idle but when press on gas will slowly rev and die. Un did exhaust before cat thinking it was clogged same thing.
Check engine light is on.
Bought 2 scanners, both would turn on but no signal from ecu.
Bit the bullet and bought a scanner for obd1 and 2
Turns on, still no link.
Whats going on?
Bad ecu?
Replaced:
New fuel pump
New fuel filter
New spark plugs
Used tps
Used fpr
Used cps
Whats going on?
Bad ecu?
Could be bad ECU.
Check OBD fuse 7.5A.
On ODBII plug following:
Check #16 terminal for 12v power at all times. This is a black wire.
#4 wire is grounded, white/black.
#5 is wire shielding wire, brown.
#7 is signal wire from ECU, white.
With OBD plug oriented facing you, and the wider part of the trapezoid connector on the bottom, the orientation is.
16 to 8 Top
7 to 1 Bottom
The plug only uses 4 terminals.
16 to 8 Top
7 to 1 Bottom
the_iklop
01-05-2013 09:44 PM
Nadzmik
07-22-2011 07:20 AM
LetterX
07-08-2010 10:04 PM
