Old Aug 26, 2015, 04:12 PM
How-Tos on this Topic
Browse all: Interior
Print Wikipost
Odd color coding 1998 xle camry
Old Mar 20, 2021 | 05:51 PM
  #21
The radio can have a built-in amp or a remote amp.
If a built-in amp, the radio and amp are self contained. The radio connects directly to the speakers and 12v power supply.
If having a remote amp, the radio and remote amp work together. It sends a preamp signal to the remote amp. The remote amp connects to the speakers. The 12v power supply connects to the remote amp. The remote amp then sens this power to the radio. The radio controls the remote amp such as amp on/off and mute..
Old Mar 21, 2021 | 01:13 AM
  #22
JMckee's Avatar
Car stock Amplifier, located behind the glove box.
The Amplifier with the strange cords that was plugged into the radio.. Does anyone know a aftermarket harnness that connects into this but with the aftermarket cords?
Close up clear view...
86280-AC021
Old Mar 21, 2021 | 01:14 AM
  #23
JMckee's Avatar
I'm not a specialist try to be more simplistic.. I know how to repair now detail and wire work ain't my ball park but gotta start somewhere..
Old Mar 21, 2021 | 01:17 AM
  #24
JMckee's Avatar
For those who didn't snip the harness and don't want to spend a bunch of money check this out!
Old Mar 21, 2021 | 01:49 AM
  #25
JMckee's Avatar
the left side i counted a 14-pin oem, what I need is a aftermarket harness to hook into the stock Amplifier with after market cords the it will be easy..
Would any of these work?
14-pin OEM harness
15-pin OEM harness
Old Aug 17, 2021 | 08:08 PM
  #26
Derrick's Avatar
Default Solution
Originally Posted by jahl519
attached is a photo of the wires.. from what I see, there is:
these are the speaker wires.. just don't know which are + and -
2 black (identical)
2 red (identical)
2 white (identical)
2 green (identical)
1 blue
1 gray
1 yellow - battery
1 red/black
1 brown
1 white/green
__________________________________________________ ____
I've searched multiple sites and forums... seems that this wire coding does not match what normally comes in a 1998 xle camry..
normal coding is:
Audio wiring diagram to help replace Toyota Camry factory radio stereo - Toyota Nation Forum : Toyota Car and Truck Forums
any ideas on which wire is which?
Hi! I know this is response is 10 years late but I just got a 1997 Toyota Camry LE, wanted to swap out the stereo, and had the same problem.
The wiring harness you showed in the picture is not the one you want to work with. Further back into the console, on the right side, there are two harnesses with the correct wires. Unplug them, and google a 1997 toyota camry radio wiring diagram (I used 12Volts’ diagram), attach your new wiring harness for your stereo, and it will be good to go.
I attached a couple images so you can see where the correct harnesses are. The harness that’s half cut and stripped was the same harness you had a problem with- I ended up taping the ends and shoving it in the back, as you don’t need it.
Hope this helps anyone who needs it!
here are where you can find the correct harnesses
here are the correct harnesses that you will need to cut, strip, and attach to your new stereo
here is the incorrect harness that I was working on originally, the one you were confused about. Forget this one
cope242
Feb 23, 2019 10:37 AM
motnamser
Feb 15, 2015 10:03 AM
vortexnut
Sep 29, 2013 12:55 AM
puddingpete
Mar 3, 2013 12:31 PM
mike9812121298
Feb 6, 2009 10:09 PM
