'94 camry engine problems
Old Oct 17, 2012 | 06:17 PM
theiceman447's Avatar
Default '94 camry engine problems
Hi, got a 94 with a 2.2 auto. Almost spun a rod back in July. Motor was idling and siezed up. Replaced crank, rod and main bearings. It still has a clunking??? Sort of sound coming from the bottom end. I may have mixed up endcaps on rods. Could that be the issue? Any help would be great. Thanks.
Old Oct 17, 2012 | 07:14 PM
It sounds similarto lifters, but its in the bottom. End.
Old Oct 18, 2012 | 05:08 PM
Bump!
Old Oct 20, 2012 | 08:48 AM
Mixing rod bearing caps is not good.
Does the clunk noise become louder with engine loading?
Did you put the balance shaft system back together correctly?
If lifter noise, a tap or clunk.
Us a section of hose as a stethoscope to narrow down the area in addition to being in the lower end such as front or back of engine, etc.
Gregthegen
Feb 10, 2013 04:20 PM
jeeperman
Oct 27, 2008 08:19 PM
miggypilares
Jan 13, 2008 01:14 PM
SarahS
Dec 20, 2006 07:53 PM
alrtytn
Nov 1, 2006 04:56 PM
