Camry 1998 Ticking/Tapping Noise
Old Aug 11, 2011 | 12:44 PM
OldFox's Avatar
Default Camry 1998 Ticking/Tapping Noise
Greetings to all,
I have a Camry 98 CE 4Cyl with 280K Km.
I added Seafoam thru the intake throttle and let it soak for a while.
When I started the engine, it gave a ticking/tapping noise.
The engine is still running normally with smooth idle.
I changed the engine oil with 10w30 but no effect.
The OBDII live data analyzer shows every thing normal except the following:
ST FTRM1 (%0) - it stays at zero rather than going between +/-5%.
I tried using the stethoscope but could not locate the noise source.
Please advise.
Thanks
Old Aug 11, 2011 | 01:33 PM
Unless you added a LOT of Seafoam such ozs and ozs resulting in engine hydro lock do to liquids in the cylinder, spraying the intake with a little is not going to harm the engine. If you waited long enough a good deal of it would evaporate before start up.
Check for noise under the valve cover due to valve clearance-normal and at the injectors. They can click at what seems an abnormally high level, but normal.
A small amount of Seafoam is not going to damage the fuel system, suggest you ignore the fuel trim. If there is a problem the computer over time will trip the check light.
Old Oct 12, 2012 | 07:28 PM
grizlbr's Avatar
Just a WAG: solvent lifted some carbon deposited on outer edge of piston top or edge of combustion chamber. Taping? Take a plumbers camera and remove spark plugs and look or remove plugs and check for carbon spots, see one that is worst bring piston half way up and get a huge swab and swab it out. Do not ask where I saw the 6 inch giant swabs!
PatG
Nov 25, 2012 09:50 AM
godfreypilot
Oct 18, 2011 02:08 PM
meagan_maleigh
Mar 18, 2011 11:12 PM
ksack001
Aug 1, 2010 01:00 AM
carNewbie
Jan 31, 2008 06:43 PM
