1998 Camry Power Window
Old Aug 9, 2008 | 11:13 AM
honsby's Avatar
Default 1998 Camry Power Window
Okay, so for about 2 months, my rear right power window has been messed up. It'd go up a little at a time and down a little at a time. Signs that showed that it was dieing I suppose.
The other day, my cousin tried putting it down and I told her not to, but she did not process what I said fast enough and put it down anyways.
It wouldn't go up. I guess it finally broke.
I had my uncle who used to be a mechanic check it out this morning.
He checked everything and it turns out the window motor is dead. (big surprise. :P)
My question is..
Can I replace it with another brand of power motor made for the toyota camry?
I can't find the one that was already in there.
I don't know if it's stock or what, but I think it is.
It says TOYOTA on the front side with a 3 lines of numbers and then DENSO.
I was wondering if I could replace it with one of these.
Old Aug 10, 2008 | 04:44 AM
pedro's Avatar
Default RE: 1998 Camry Power Window
ORIGINAL:Can I replace it with another brand of power motor made for the toyota camry? Iwas wondering if I could replace it with one of these.
I don't see any reason why not. You're in a better position to compare the one on the car with the one in the pictures.
Old Aug 10, 2008 | 10:32 PM
musthave's Avatar
You should be able to buy and rebuilt or after market at a part store.
Old Aug 11, 2008 | 08:40 AM
Check to make sure if the issue is the motor or regulator. The parts can be purchased individually or as a unit.
Old Aug 11, 2008 | 02:13 PM
honsby's Avatar
I'm sure it's the motor and not the regulator.
Can I use my old regulator with an aftermarket motor?
Old Aug 11, 2008 | 04:12 PM
Yes
96cam
Mar 8, 2017 08:55 AM
LetterX
Oct 30, 2010 06:20 PM
emlga
Mar 28, 2009 08:07 PM
Tommy D
Aug 5, 2008 10:20 AM
lavalleemike
Jun 25, 2006 11:28 PM
