97 camry rough idle
Old Feb 8, 2012 | 02:55 PM
cwmobile's Avatar
Default 97 camry rough idle
engine runs rough between 800 and 1200 rpms. good even compression,new head and gasket, code p1210, 4 cyl. erratic idle. random multiple misfire,misfir cylinder 3. replaced coil and no change,new plugs,wires. i know the timing is right.what can it be? no info on code p1210.
Old Feb 8, 2012 | 03:06 PM
cwmobile's Avatar
also gas smell when setting overnite in garage very strong
Old Feb 8, 2012 | 03:56 PM
dboy11's Avatar
That's not something to play with. Take the care back to fixed it last. A fuel leak results are not good
Old Feb 8, 2012 | 06:55 PM
P1210 Injector Control Pressure Above Expected Level. Not sure this engine has injector pressure monitoring. The code is listed but not for this year of car/engine.
Are you getting random misfire trouble codes?
Did the engine ever run correctly after the head work?
Try to run down the source of the gas smell. The engine should be sealed except for the intake manifold.
Check under the car in front of the fuel tank for leaks, this is where the EVAP system is.
slvrspec8
Aug 7, 2010 09:08 AM
gfcamry96
Jun 21, 2009 06:48 AM
ldballoon4
Jan 21, 2009 06:35 PM
chinik
Feb 13, 2008 04:54 PM
green97le
Jun 8, 2006 12:32 AM
