No fire
Old Aug 31, 2023 | 12:36 AM
  #11
Is the dash security light on?
See private message sent.
Old Aug 31, 2023 | 11:11 AM
  #12
Granpa49's Avatar
I hope you got my reply to the private message.
IT'S RUNNING!
The ignition coil wiring diagram on page 106 shows a fuse labeled INJ that controls power to the coils. That fuse is in the main body fuse panel underneath the dash. When I pulled it I could see that it was bad. Not having spares that would fit, I robbed the one out of the FOG slot and inserted it into the INJ slot. The car cranked right up.
Thank you a million times.
Old Aug 31, 2023 | 01:40 PM
  #13
Great job!
Old Aug 31, 2023 | 04:08 PM
  #14
Granpa49's Avatar
Reminds me of the old adage that you always find the things you are looking for in the last place you look.
Old Sep 8, 2023 | 07:35 AM
  #15
Granpa49's Avatar
I learned one thing from this that might be of help to anyone having a similar problem. If you have a bad connection to one of the coils, the immobilizer won't let t he engine run. It will crank but die in about two seconds. Simply remove the #1 coil connector and crank it again. If it dies, replace the #1 connector and remove the # 2 connector and crank it again. Keep doing this until the engine cranks and runs. Whichever coil connector you have off at that time is where the problem is.
sb87cam
Apr 6, 2022 04:06 PM
Toycamry
Jan 29, 2019 05:21 PM
mytecho
Jan 18, 2015 01:58 PM
chaoticwolf88
Dec 22, 2011 08:19 PM
johnradfx
May 27, 2010 08:29 AM
