What is the OBD2 hack to check ATF temp?
Old Aug 30, 2017 | 11:29 AM
robb's Avatar
Default What is the OBD2 hack to check ATF temp?
I'm having transmission issues and want to check the fluid level (2011 4 cyl 56k). The manual is worthless for this, but I have read how to do it elsewhere in the past. I remember the fluid has to be between 104 to 113°F before removing the drain plug to see if the fluid drips out over the tube.
I do have a scanner with live data but it doesn't display tranny fluid temp. But I remember also reading about connecting some OBD2 contacts in order to see if the temp is in range.
Unfortunately, after hours of searching I can't find the OBD2 hack again.
Any help would be appreciated.
Old Aug 30, 2017 | 01:05 PM
Old Aug 30, 2017 | 02:03 PM
robb's Avatar
Default requires scanner to read temp
I already saw that. It says to buy a scan tool to read the temp. As I said, I remember seeing a hack to connect some OBD2 contacts that then somehow indicates that you're in the correct temp range.
Old Aug 31, 2017 | 12:06 PM
Check at Toyotanation.com.
Old Aug 31, 2017 | 08:03 PM
robb's Avatar
I have. No info or responses.
Old Sep 1, 2017 | 10:44 AM
Ign key off, jump terminals 4 and 13.
Press/hold brake pedal.
Start engine (all accessories off). Indicators lights may blink.
Slowly shift between P and D, then to P.
Shift between N and D and back at an intervals of less than 1.5 secs, for 6 secs or more.
D shift indicator should illuminate for 2 seconds. If not for 2 secs repeat procedure above.
If D illuminated for 2 secs, move shift lever between N to P.
Release brake pedal.
Remove terminal jumper.
Idle engine until D indicator illuminates. Fluid will be between 95F and 113F.
If D indication blinks fluid is above 113F.
Old Sep 1, 2017 | 11:39 AM
robb's Avatar
Thumbs up Thanks!!
I knew I hadn't dreamt it. Thanks for finding it!
94camguy
Jan 3, 2025 09:28 PM
Chutem
Mar 18, 2023 09:53 PM
jdmgeek
Jun 14, 2017 12:35 PM
dirty hands
Sep 22, 2014 11:24 AM
zcpro
Jan 12, 2009 01:59 PM
