1990 Camry help question
Old Jul 28, 2016 | 12:19 PM
Borghese510's Avatar
Default 1990 Camry help question
I have a 1990 Camry that will not start for 1 hour if I drive it a short distance and park. Battery is fine, alternator is fine. It also happens if I drive a longer distance. In other words, I drive a mile or so, turn the car off, come back before 1 hours passes and it will not turn over. If I wait an hour, it will turn over fine. Can any one give me some suggestions. The mechanics want me to spend money on everything but the problem. Thanks.
Robert
Old Jul 28, 2016 | 03:03 PM
dirty hands's Avatar
4 cyl engine or V6
if it will not turn over ( no crank at all )
will be starter or ignition fault
if you do have crank over ... will be spark or compression related
check starter relay
check that you have
12 volts through the starter cable from the battery positive terminal to the starter
or the starter solenoid itself
ignition assembly faulty
Old Aug 6, 2016 | 06:35 PM
g3bill's Avatar
i'd say starter or solenoid as above, not so likely to be the coil or would stop while driving then can restart after waiting sometimes till real bad. Its not a loss if you replace electrical parts if they turn out not to be the problem, just better reliability usually.
ianbrown75
May 12, 2011 10:41 PM
ejmaue
Jan 18, 2010 01:07 AM
mbas
Jul 1, 2008 06:02 AM
rexydg
Jun 15, 2007 11:26 AM
nimainewman
Mar 22, 2007 11:49 PM
