Heat problem
Yes, if having some mechanical skills a DIY.
The radiator will need to be drained of coolant. Before starting the job obtain service manual info. Perhaps a Haynes manual, your library may have manuals, search internet for "changing thermostat + your engine model." If 4 cylinder a 5S-FE if V6 engine a 1MZ-FE.
Also check the current coolant level in the radiator (engine cold) and make sure the overflow reservoir is at the required level. Low coolant can also cause your problems.
